| | | Forums66 Topics128,049 Posts1,055,678 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 29 'Bolter | | 'Bolter Joined: Sep 2003 Posts: 29 | Bolters,
I’m having trouble with both roll-down windows on a 53 AD.
I bought the whole door rubber kit some time ago and installed it. At first all was well, but over time both windows have tightened up, and won’t go past halfway down without pushing on them. Can this be due to older, worn window regulators? Or is there some advice or experience on lubricating/greasing the window channels that might be the way to keep things slidin’? | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | You could try to spray silicone spray in the channels. Mabey the channels have build up of felt in them. | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | My new felt channels disintegrated in short order. The gum and felt balled up in the channel, but just down in the door, not up around the glass. I tried a number of fixes, but finally scraped it all out from the lower section. Works fine now. | | |
