4 members (Hotrod Lincoln, Otto Skorzeny, Bill Hanlon, 1 invisible), 70 guests, and 1 robot.
Topics128,090
Posts1,056,026
Members48,432
#1232685 08/30/2017 10:06 PM
Former BMW Rider
Former BMW Rider
I need to install a Redi-Sleeve on the harmonic balancer of my 235. The instructions call for a "non-hardening sealant" to set the sleeve to the harmonic balancer. The guy at my FLAPS suggested Permatex Black Ultra. I've heard of Red Loctite being used, but someone said it turns soft when subjected to significant heat?
What are you using to set the sleeve?
Andy
His: 1947 Chevrolet 3104
Hers: 2008 American Saddlebred
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
H Online: Content
If the balancer gets hot enough to soften red Loctite (500+ degrees) I hope your fire insurance policy is paid up! I like to put the part in a freezer overnight if possible and put a couple of drops of Loctite in the wear groove of the balancer I'm trying to cover up just before tapping the sleeve on. Once the temps normalize, it's on there to stay.
The sleeves I have used come with red loctite.
My Blog
Former BMW Rider
Former BMW Rider
Well, red loctite it is!
Out of curiosity, I contacted Federal Mogul and spoke with a technical support person. Their specific recommendation was Loctite 609. As you can see, it's for cylindrical bonding.
Permatex also has a comparable product, Permatex 60950.
Unfortunately, these products are not on the shelf at your FLAPS. So if red loctite has been working for you guys, it will work for me. I even have some out in the garage......
Thanks you guys,
Andy
Riding in the Passing Lane
I always use RTV on them. It is slick & helps it slide on & seals it. Those sleeves stretch when they are pressed on. No way can they come loose.
1972 Chevy c10 Cheyenne Super
Andy,
The grooves in my balancer were deep, so I was concerned about creating a "hollow". I used some JB Weld to fill the groove and put some rtv past it on the shaft. No leaks so far, but as you know I'm not a high miler.
Have fun.
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill
Former BMW Rider
Former BMW Rider
Hi Bill,
I had the same problem and used some JB Weld too. It seems like it filled the groove. I'll be pressing on the sleeve early next week.
The kids and grand kids are coming for the weekend, so Granpy (not Grumpy) won't be hibernating in the garage this weekend.
BTW, I've got the 'new' rear end (3.90) installed and hope to have the engine buttoned-up and in this month. The SM420 four speed is ready and waiting, once the custom drive shaft is built and the spring perches are welded, I'll be 'On the Road Again' just like old Willie Nelson............. yahoo
Andy
