6 members (Jon G, Pre '68 Dave, Rusted Nut, Woodcmiami, 55shaker, Bill Hanlon), 122 guests, and 2 robots.
Topics128,109
Posts1,056,260
Members48,439
#1231276 08/21/2017 5:51 PM
Big Bolt Forum Co-moderator
I was at a truck show on the weekend and saw a 1/2 ton truck with an S-10, T-5 transmission in it. Would this work in a Big Bolt and would it give you a little more road speed, or does the rear end limit that. Obviously, I don't know much about drive lines, so don't beat me up to badly if this is silly question.
1948 Chevy 2-Ton
Crusing in the Passing Lane
T-5 transmissions are not rated for large trucks, review last two day's comments. Changing the rear gears would be a start.
What ratio do you have now?
What wheel bolt pattern do you have?
What is the gross weight of your truck?
What kind of loads of you plan?
Do you have juice or air brakes?
Do you plan on a show or work truck?
Do you plan on much freeway driving?
These are some questions you might answer before deciding which route to follow. For example, look at trucks with similar GVW to yours. There are OD trans.' For several size trucks-NV-4500; RR RTO'; Eaton FSO, etc, depending on size of truck. Whatever trans you select, you might need to raise the diff. ratio.
Keep lurking on here.
Ed
You told me all I wanted to know. I was checking to see if it would be a good idea for my 1948 two ton, that would be used to haul my antique tractor to shows. I am confident that the best thing would be stay stock. Thanks. I was just thinking of getting a little more roads speed.
1948 Chevy 2-Ton
That and the T-5 is like the weakest 5 speed trans you can get lol. Wont hold up for anything behind a 300+ hp sbc in a light vehicle. Ask me how I know :p
Super55 #1231887 08/25/2017 12:47 AM
Depending on your diff. ratio, and bolt pattern, a GM ff 14 bolt might work for you. Lots of ratios, strong, plentiful, cheap, however only comes in 8 on 6.5 bolt pattern.
Ed
Big Bolt Forum Moderator
you might also look at the Ranger overdrive unit. It goes between the bellhousing and transmission. I have one I am going to be putting in my 58 2-ton one of these days (just need to get around to it!)
Mike
1 Offline
You want an overdrive you should try this guy out. I have one going to put in a 85 Chevy and thinking about putting one in my 47 2-ton
http://www.advanceadapters.com/prod...overdrive-27-with-a-5125-retainer-index/
1947farmer
1947 2-Ton Chevy
Story in the Stovebolt Gallery
More pix in Photobucket
1977 3/4-ton
1985 2.5-ton
2- 1947 Allis WC
1- 1949 Allis allcrop
1- 1955 Allis WD-45
1- 1976 Allis 7040
"If it ain't broke you ain't trying"
