0 members (),
120
Mod | | | Forums66 Topics128,093 Posts1,056,474 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2017 Posts: 22 New Guy | | New Guy Joined: Aug 2017 Posts: 22 | Hi, I've just pick up a couple of 40s chev trucks. Iam thinking about putting a complete drive line from either a 3500 Silverado or Dodge Ram into them. Has any one done this and how did it turn out?
Thanks heaps | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Duramax might be too wide for '40's trucks, most of which were inline 6's. 5.9 Cummins might be too long except for COE models. 4bt might be best choice.
Modern driveline, front axle in particular might be too wide, GMC have rare wide front fenders, Stude have spacer strip that can be easily widened.
Troll through build's on here to get ideas.
Ed
| | | | | Joined: Sep 2013 Posts: 1,366 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,366 | Well, up front I'm a Cummins fan. Bought a new 1995 Dodge Cummins (still drive with 250k miles) and had 3 at one time. Rebuilt a few, and turned up many (with full gauge packages only, aluminum pistons do melt). All that said, I really appreciate the simplicity of the mechanical injection pump 4bt and 6bt engines. My first choice would be a 4bt with the inline injection pump. They're not hard to find since they were the engine of choice for the utility trucks used by bakery's, delivery company's and who knows how many others.
Electronics, don't need no stinking electronics with a mechanical fuel pump Cummins. Now they do require electrons for the starter, and fuel shut-off solenoid....but it's easy to replace the electric solenoid with a cable, ala tractor fuel shut-off. Pull to kill the engine, push in to start. That's what's on my 95 both for simplicity and it's a pretty good theft deterrent.
MGP, it's not uncommon for 4bt conversions to get near 30mpg. 6bt also do very well.
All the above said, the biggest advantage to the Cummins is the stone like simplicity, less to go wrong and they'll run till just before the sun burns out.
Buy a clapped out 1991 1/2 (Dodge added an inter-cooler for the turbo at mid year in 91) to 1997 Dodge Cummins, harvest the running gear and get to work.
Oh, and the easier path would be to strip the body off the Dodge, then graft the Chevrolet body to the late model frame/running gear. Benefits include modern brakes and suspension. Easier and safer.
Good Luck, RonR
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Saw a 5.9 Cummins in an AD (not COE) in Shelton, WA at one time. I didn't have a camera with me. Putting something in the classifieds of the Shelton Journal might stir up a contact. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Apr 2010 Posts: 436 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 436 | Not sure about the fit and finish of swapping in a Cummins, but I have an '06 Dodge 2500 4x4 with the 5.9 Cummins and I love it. Good drive train. | | | | | Joined: Sep 2013 Posts: 1,366 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,366 | Fit and finish are totally based on the fab skills of the converter. Lots of welding, fitting, along with a well stocked shop and high level skills required to make this conversion happen.
RonR
