1 members (klhansen),
136
10
Mod | | | Forums66 Topics128,281 Posts1,058,470 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 1,135 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,135 | Installed the seats tonight to check clearances for 3 point seat belts. The stock pedestal and rail mounts are being used. The cushion and back were reupholstered. I noticed that the clearance between the top of my head and the cab top is only about 4 inches, which is much less than in my '37. Also, with the seat adjusted as far back as it will go my legs don't have as much clearance as I would expect for someone of average height. Is this a typical experience for these model trucks? | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Yup, people were smaller back then. I have the same leg room issue in the '62 C-10 but then I'm 6'1".
| | | | | Joined: Feb 2008 Posts: 1,135 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,135 | Oddly, the fit in my '37 half ton is better and more comfortable even though the seats aren't adjustable. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Hope you have a tilt steering wheel - makes life easier ! | | | | | Joined: Feb 2008 Posts: 1,135 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,135 | No. The goal is to restore this one. I did find out the dimensions I have for clearances match another one of these that was recently restored. | | |
