| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2016 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2016 Posts: 34 | Driving to cruise night in my stock '52 4400, all of a sudden it sputters and almost was underivable Black smoke and the only way I could make it home was to rev the engine at a high idle. I pull the plugs and clean them, check the ignition and found nothing. Played with the idle screw and even turning it al the way in, no change. So I think it was a internal leak. Oh ya, main jet vibrated out and was sloshing around in the bottom of the carb. Reassembled and installed and as good as new. The engine vibration at cruise speed must of jarred the jet out.First repair that cost me nothing but time. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Good find, good fix, Rich | | | | | Joined: Aug 2017 Posts: 55 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 55 | Good find Rich. Did you ever make Cruz night? | | | | | Joined: Aug 2016 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2016 Posts: 34 | Made it in traffic. Found out truck can take off from dead stop in 4th gear .Panic through intersection before red light. Tough old truck with original clutch. | | |
