7 members (cmayna, D B Cooper, Bisbee, Otto Skorzeny, LuckyLee, 2 invisible), 73 guests, and 2 robots.
Topics128,131
Posts1,056,723
Members48,454
#1231911 08/25/2017 3:17 AM
Installed the seats tonight to check clearances for 3 point seat belts. The stock pedestal and rail mounts are being used. The cushion and back were reupholstered. I noticed that the clearance between the top of my head and the cab top is only about 4 inches, which is much less than in my '37. Also, with the seat adjusted as far back as it will go my legs don't have as much clearance as I would expect for someone of average height. Is this a typical experience for these model trucks?
Yup, people were smaller back then. I have the same leg room issue in the '62 C-10 but then I'm 6'1". dang
Oddly, the fit in my '37 half ton is better and more comfortable even though the seats aren't adjustable.
Hope you have a tilt steering wheel - makes life easier !
1940 Chevy KC 1/2-Ton
No. The goal is to restore this one.
I did find out the dimensions I have for clearances match another one of these that was recently restored.
Moderated by  ndkid275, Phak1
