| Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Have to make side mounts, see if larger radiators were/are available for that truck, might have to move or make new crossmember-trivial. Does the 366 you found come complete? Bellhousing, clutch fork, flywheel, clutch, starter, engine mounts, power steering pump, alt., etc.
Might also be good to measure total length of both engines, fan to distr.
Ed
