8 members (klhansen, Shade Baby, Shaffer's1950, JW51, Cosmo, Oswald, 2 invisible),
57
Mod | | | Forums66 Topics128,075 Posts1,055,919 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 1,043 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,043 | Hi folks. I was thinking of putting a 5 speed on my column. I'm going to run a Tremec 3650 5 speed. I have the mech. figured out just wondered if you think it would be stupid?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | On a 1953 truck?
Is this for use with your blown 292?
Let us know how these work out for you. | | | | | Joined: Apr 2016 Posts: 1,043 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,043 | Yes. Took a while to figure out how to compensate for the side to side movement of trans.
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I drove a 5 speed on-the-tree Datsun pickup once when stationed in Okinawa back in 74 . It was a RHD but the shifter was on the right side of the steering column like LHD models are so it wasn't hard to master. Would be interesting to follow your build. | | | | | Joined: Apr 2016 Posts: 1,043 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,043 | I've been stuck in PA since the 6th of Feb. building a dry ice plant. Should be home in Oct. then plan to start a build journal here. Can't wait. I've had this truck since 1980 when I got out of the Navy.
| | | | | Joined: May 2017 Posts: 50 'Bolter | | 'Bolter Joined: May 2017 Posts: 50 | I think it'd be awesome if it works, I'd love some more details about your plans. | | | | | Joined: Jan 2001 Posts: 1,423 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,423 | What fun! I love my 3onthetree! There is a guy on the left coast that has a 4onthetree Saginaw with a cable pull/push for Reverse. Good for you!
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Dec 2006 Posts: 206 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 206 | | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | So I am guessing that you are taking on this adventure because you are bound and determined to make a top-loading Tremec 3650 5 speed work in an old truck, but you are having a problem with the extremely rear mounted shifter location. I was given a brand new one of those babies and I wanted to use it in the worst way, but I bailed out because of my disdain for the complicated arrangement of parts of a 3 on the tree, not to mention making it a 5 on the tree. (actually that ambitious thought never even occurred to me). I would like to see what you came up with to mate a column shifter to a top-loading transmission. Carl
| | | | | Joined: Apr 2016 Posts: 1,043 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,043 | THANKS to everyone. As far as the Tremec 3650 being too far back if I just flip it 180 degrees it will move it forward where it needs to be does't change the shift pattern. Just have to make a new shifter bar to clear the tranny and raise it up a little. Just like the idea of the column [censored] for the cool factor. Also the hydraulic throw out bearing gives me more room for exhaust.
