Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (55shaker, Bill Hanlon, Jon G, 78buckshot, TrknGMC, Joe H, 1 invisible), 99 guests, and 3 robots.
Topics128,274
Posts1,058,436
Members48,490
#1230448 08/17/2017 12:51 AM
Hi folks. I was thinking of putting a 5 speed on my column. I'm going to run a Tremec 3650 5 speed. I have the mech. figured out just wondered if you think it would be stupid?
On a 1953 truck?
Is this for use with your blown 292?
Let us know how these work out for you.
Yes. Took a while to figure out how to compensate for the side to side movement of trans.
V
V Offline
I drove a 5 speed on-the-tree Datsun pickup once when stationed in Okinawa back in 74 . It was a RHD but the shifter was on the right side of the steering column like LHD models are so it wasn't hard to master.
Would be interesting to follow your build.
I've been stuck in PA since the 6th of Feb. building a dry ice plant. Should be home in Oct. then plan to start a build journal here. Can't wait. I've had this truck since 1980 when I got out of the Navy.
Z
Z Offline
I think it'd be awesome if it works, I'd love some more details about your plans.
ODSS President
ODSS President
What fun! I love my 3onthetree! There is a guy on the left coast that has a 4onthetree Saginaw with a cable pull/push for Reverse. Good for you!
~ Cosmo
1949 Chevy Half Ton
Dave Chapman
The Hollister Road Company
713-937-0387
[email protected]
www.hollisterroad.com
www.thoroco.com
So I am guessing that you are taking on this adventure because you are bound and determined to make a top-loading Tremec 3650 5 speed work in an old truck, but you are having a problem with the extremely rear mounted shifter location.
I was given a brand new one of those babies and I wanted to use it in the worst way, but I bailed out because of my disdain for the complicated arrangement of parts of a 3 on the tree, not to mention making it a 5 on the tree. (actually that ambitious thought never even occurred to me).
I would like to see what you came up with to mate a column shifter to a top-loading transmission.
Carl
THANKS to everyone. As far as the Tremec 3650 being too far back if I just flip it 180 degrees it will move it forward where it needs to be does't change the shift pattern. Just have to make a new shifter bar to clear the tranny and raise it up a little. Just like the idea of the column [censored] for the cool factor. Also the hydraulic throw out bearing gives me more room for exhaust.
