5 members (fonz8261, 78buckshot, Gdads51, Hotrod Lincoln, 1955 1 Series), 74 guests, and 2 robots.
Topics128,180
Posts1,057,067
Members48,460
On the panel behind the cab that bolts to the top of the running board there is a hole on the top end toward the cab. The tab on the other end bolts to the fender. Is there suppose to be a bracket on that corner? 1951 3100.
1/2 ton, 3/4 ton, 1 ton?
On 1/2 ton the answer is no.
I do not know about 3/4 and 1 ton.
it is a 1/2 ton Just seems like that panel is a little flimsey on that end. Do not have the fender mounted yet so we will see. Thank you.
Fox Offline
On my 1 ton there is an S shaped bracket that bolts to that front tab, snakes under and around the board and bolts through the "step" surface of the board. It provides a lot of support and on the very long 1 ton splash apron it definitely needs it. I will check my 1/2 ton board tomorrow for you and snap a photo of the bracket.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
My 3/4 ton has the same "S" bracket
~ Dave
1/2 tons have the s-bracket at the front of that panel.
(Misunderstood tigman's question.)
Fox Offline
Here are some pictures of what that bracket looks like:
https://goo.gl/photos/yopXVVQ348vEbNAa9
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Thank you Fox. i was wondering what that single hole in the running boards was for lol. I saw those brackets somewhere but did not know what they were for. Another mystery solved.
How much gap if any is between the filler panel and the bottom of the box?
Fox Offline
Approximately 1/2". You can loosen the bolt on the running board and slide the bracket to help set the gap.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Thanks again will post pictures soon Just about done 30 year project right on schedule !
So that is what they look like! Both of mine have rotted ends and I haven't found replacements. Does anyone have a source or maybe a fab drawing to make a functional replacement?
NHluvstruck...
1951 3100 5-window,.sold, regretted
https://stonefacegarage.wixsite.com/mysite
51 Chevy Restoration Page
Nhluvstruck: I have a pair of those braces in perfect shape with light surface rust, left overs from making 2 good running boards out 4 junk ones. PM me if interested. Running board braces
Good luck, Dave
1948 5-window 3100 Chevy
327 V-8 TBI 700R4 Posi 3.73
"Old Blue"
More pix on Flickr
Personal offers and transactions should be made through Private Message.
