1 members (klhansen),
125
Mod | | | Forums66 Topics128,186 Posts1,057,318 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 41 | On the panel behind the cab that bolts to the top of the running board there is a hole on the top end toward the cab. The tab on the other end bolts to the fender. Is there suppose to be a bracket on that corner? 1951 3100. | | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | 1/2 ton, 3/4 ton, 1 ton? On 1/2 ton the answer is no. I do not know about 3/4 and 1 ton.
| | | | | Joined: Nov 2012 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 41 | it is a 1/2 ton Just seems like that panel is a little flimsey on that end. Do not have the fender mounted yet so we will see. Thank you. | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | On my 1 ton there is an S shaped bracket that bolts to that front tab, snakes under and around the board and bolts through the "step" surface of the board. It provides a lot of support and on the very long 1 ton splash apron it definitely needs it. I will check my 1/2 ton board tomorrow for you and snap a photo of the bracket. | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | My 3/4 ton has the same "S" bracket
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | 1/2 tons have the s-bracket at the front of that panel. (Misunderstood tigman's question.)
| | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Here are some pictures of what that bracket looks like: https://goo.gl/photos/yopXVVQ348vEbNAa9 | | | | | Joined: Nov 2012 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 41 | Thank you Fox. i was wondering what that single hole in the running boards was for lol. I saw those brackets somewhere but did not know what they were for. Another mystery solved. | | | | | Joined: Nov 2012 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 41 | How much gap if any is between the filler panel and the bottom of the box? | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Approximately 1/2". You can loosen the bolt on the running board and slide the bracket to help set the gap. | | | | | Joined: Nov 2012 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 41 | Thanks again will post pictures soon Just about done 30 year project right on schedule ! | | | | | Joined: Jul 2013 Posts: 160 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 160 | So that is what they look like! Both of mine have rotted ends and I haven't found replacements. Does anyone have a source or maybe a fab drawing to make a functional replacement? | | | | | Joined: Mar 2004 Posts: 256 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 256 | Nhluvstruck: I have a pair of those braces in perfect shape with light surface rust, left overs from making 2 good running boards out 4 junk ones. PM me if interested. Running board bracesGood luck, Dave | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Personal offers and transactions should be made through Private Message. | | |
