1 members (TooMany2count),
81
Mod | | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I must not have these installed right because if I push the inside door handle forward, the 11 1/2" door link falls off. Works fine if I pull the handle instead but today for some reason I pushed it forward so now get to take the door panel off and try again. I must be missing something.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | After looking at it this afternoon, I think the inside door handle should push forward to open. Is that correct? There is a tab on the 6 inch or so wide brace that spans the door and holds the latch/lock and inside handles. I'm thinking that is to keep the door handle from being pulled back too far. Is that correct? If so then I can't attach the latch connecter with everything else in place. I'll have to take the brace and latching mechanism out. I'm fixing to do that tomorrow so if that is not right please lemme know.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | OK, got it. As per my last post, the handle should push to open with the tab preventing it to turn too far so the link can fall off. Now on to alignment.
Dennis
40 Chevy 1/2 ton
