| | | Forums66 Topics128,172 Posts1,057,105 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2017 Posts: 120 'Bolter | | 'Bolter Joined: Jun 2017 Posts: 120 | I have seen that this subject has been talked about before but I guess Jim Carter no longer carries this upholstery.
Has anyone found a fabric source of this material?
I have discovered that my truck has the deluxe fabric interior underneath some black upholstery.
1954 Deluxe 1/2 ton Chevy PU | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Two-tone interior, or one color deluxe interior. If two-tone interior, what colors; or, deluxe cab's gray top and burgundy sides (did you call Jim Carter)? http://www.1954advance-design.com/Documents/SalesBooklet/Page%2033.jpg
| | | | | Joined: Jun 2017 Posts: 120 'Bolter | | 'Bolter Joined: Jun 2017 Posts: 120 | It is the two-tone blue interior. Lighter blue cushion vinyl sides with kind of a checked fabric on the seat and back. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | posey,
You have nothing to lose by calling Jim Carter. If you are lucky, you might get through to Jim.
He might be willing to do a special order for you?
He used to use a local upholsterer. If he does not want to deal with this, ask him if he would give you contact information for the upholsterer he used to use. She was very accommodating with me (communicating through me, via Jim Carter).
Good Luck - and, and please let us know what do.
| | | | | Joined: Jun 2017 Posts: 120 'Bolter | | 'Bolter Joined: Jun 2017 Posts: 120 | | | | | | Joined: Aug 2001 Posts: 1,300 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,300 | | | | | | Joined: Jun 2017 Posts: 120 'Bolter | | 'Bolter Joined: Jun 2017 Posts: 120 | thanks, will give them a try | | |
