3 members (WICruiser, baldeagle, Peggy M), 214 guests, and 5 robots.
Topics128,106
Posts1,056,214
Members48,436
#1231057 08/20/2017 12:54 PM
Nearing the end of the rewire project. Lighter as two wires, one fused, assume this gores to hot, the other is off the shell/case; does that go to ground? Denis
Thanks Denis
Used to drive Subs, prefer old rides
1952 chevy 3100, 5 window
Ground.
RonR
1970 340 Duster
1964 CJ5
Yes, most-likely/maybe, unless there is a light bulb.
The original accessory cigarette/cigar light was grounded through the case/"nut" connection to the dash.
Where did you buy it, and, what is the part number?
Jim Carter
I'd bet that is for a ground wire?
