4 members (MickeyP, Ole49GMC, Tronman, Peggy M), 83 guests, and 1 robot.
Topics128,043
Posts1,055,610
#1230788 08/18/2017 8:46 PM
1 Offline
Hello Guys,
When changing a 1957 Chevy 1/2 ton truck (rear wheel drive) over to a 4x4 using a Napco conversion package, can you still use the stock rear end/axle?
Hal
Yes, as long as the NAPCO front axle has the same ratio as your stock rear end.
1 Offline
Thanks 52Carl for your reply.
Hal
Hal,
I concur, I believe the 4wd conversions used the original rear axle.
Paul
Lots more pictures
V
V Offline
There was a good article in the Fall 2017 Hagerty magazine I got re. 2 Napco Stovenbolts, a 59 1/2 ton and I believe a 51 3/4 ton. It gave a limited history on the Napco conversions and it claimed they were bolt in mod's and could be removed and the stock parts reinstalled. As Carl said the gears ratio's in the front and back need to match.
I have the conversion manual and the stock rear is retained (ditto on front and rear matches).
I have a 1957 truck, it had a 1970's rear. So I changed the ring and pinions on both the front and rear to 3:38 - Patrick's kits).
This allowed good highway cruising, but the 261 and later the 283 were OK, but not a lot of "punch." I now have a 348 with
3 deuces in it. Now it has a lot of "grunt."
don
