1 members (Hotrod Lincoln), 61 guests, and 2 robots.
Topics128,049
Posts1,055,740
I am looking for a steering column clamp that adjusts the tension on the 3 speed column shifter?
Post in the Parts Wanted forum.
Agreed. But if i might ask for someone to post picture of this clamp contraption i might learn something. What does this clamp look like?
~ HB
1962 Chevrolet C10
1962 Suburban
See my BLOG post 7/12/17 HERE. My column shifter linkage was getting stuck between gears. I needed to adjust the clamp that holds the lower column bearing. That fixed the problem. No more getting stuck between gears.
So the clamp referred to above (65chevyc10) is the bracket that is held by the 1 screw shown. And do I understand that the adjustment is accomplished by twisting so the hole moves up the channel?
Thanks for pictures Lugnutz.
~ HB
1962 Chevrolet C10
1962 Suburban
There are actually two bolts. The two diagonal slots allow the lower bearing to be adjusted (by twisting) towards or away from the steering wheel end. Mine was sloppy loose and I'd get it stuck between gears.
The clamp you took 2 bolts out of on the pictures you show ,is what I need.
What exactly is it called, and were can I find one?
Chuck
Chuck
No idea what the actual name is. You will probably need to get one from a discarded original column.
Thanks! I've been looking everywhere , and can't seem to find one,
but will keep looking.
RJ Offline
i should have the steering column clamp you are looking for.
R/J Rich
(719)250-5057
personal buying/selling/transactions should take place in private messages
Yes rj. Please take this to pm.
~ HB
1962 Chevrolet C10
1962 Suburban
