4 members (Peggy M, Otto Skorzeny, klhansen, farmallb), 107 guests, and 2 robots.
Topics128,041
Posts1,055,487
Members48,424
#1230728 08/18/2017 2:43 PM
Ok, ya'll bailed me out on the brake problem so I'm begging again. I've been sick for the last 3 weeks or I would not be asking. I'd get out and find out myself. 4 to 8 more weeks and I should be good to go. Just wanted to let ya'll know the reason for all the questions. Now, on my buddy's 74 C-50 dump truck. He told me that when he pushes the brake down
at a low rpm it kills the engine, a 292 cid. He's presently bleeding the brakes now. I haven't seen the set up so I don't know what's going on. I told him I would quiz my friends on Stovebolt. If anyone knows it will be someone on here. The truck has a booster on it and I was wondering if it could be the hoses maybe dry rotted and not sealing good. Anyway, any thoughts on this? Thanks again to the best bunch of guys on the web. He is a really good guy and I am thankful for everyone helping me help him.
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
Careful Red, asking questions about a truck later than 1972 might get your hand slapped. I'm sure someone will answer your question but let's keep future questions within the guidelines of the site. Thanks.
Sounds like the brake booster has an internal vacuum leak. When you push the brake pedal it opens a valve allowing vacuum into the booster. If there is an internal leak the outside air will rush in leaning out the fuel mixture in the intake manifold and could cause the engine to stall.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #1231781 08/24/2017 2:26 PM
Consider my hand slapped. I wasn't thinking. I got one answer that I can tell him anyway. Thanks for the answer and the reminder.
If I remember correctly they had a valve on top of the booster unit that does as Mike B suggested. it should have a 1" hose to a breather . They do go bad and do as you describe
Dave Chapman
The Hollister Road Company
713-937-0387
[email protected]
www.hollisterroad.com
www.thoroco.com
thoroco #1232590 08/29/2017 10:28 PM
Thanks again for replying to my post. He will check everything you've replyed to. I will thank you for him also.
Thanks again for replying to my post. He will check on each thing you have replyed to. I will thank you for him. He helps me on my 1949 truck when I need it. Kinda hard to find go friends anymore. Opps, I put two replys on here. I'm trying out a keyboard on this tablet and I'm just not use to it. Thanks for bearing with me.
