4 members (Ponchogl, cmayna, 1955 1 Series, Hanks custodian), 197 guests, and 1 robot.
Topics128,114
Posts1,056,287
Members48,439
Anyone heard of sanding the inner bead of a powder coated wheel to keep the radial from breaking it's seat? I have heard about checking the nuts after a drive or two but this I had not heard. Want to put her new shoes on this weekend.
Cavebull
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
I'd ask tire shops if that's their practice .... also the powder coater .... and let us [who've also coated our rims] know
Crusing in the Passing Lane
I don't know if that is necessary unless Air is often let out for better traction in sand, etc.
Ed
ODSS President
ODSS President
I have ~4k miles on powder coated artillery rims, no tubes, no air loss. A sealer of some sort was used and a 'truck air stem' was used. The stem is threaded and provides a better seal. Ed raises a good concern if that is what you will be doing.
~ Cosmo
1949 Chevy Half Ton
I would not remove any paint or PC from the bead area. I would go with the theory rust and corrosion over time would cause more leaking from the bead area than the paint.
New rims are PC in the bead area but they have the safety bead hump to lock the tire bead in place.
