4 members (Peggy M, klhansen, Wally / Montana, Hanks custodian), 82 guests, and 3 robots.
Topics128,059
Posts1,055,823
#1230388 08/16/2017 4:58 PM
I removed a 216 engine with 4 speed out of my 1950 3600. I have a donor motor which is a 235 from a 1956 Belair which was an automatic. I want to put the 4 speed behind the 235. My questions are:
which pilot bushing should I get?
what about pressure plate? match the one from the 216 which is 10 3/4"
anything else I should look at?
Ed
evac34 #1230392 08/16/2017 5:05 PM
If you are staying 6v, use the flywheel, clutch-assembly, and starter from that truck.
Maybe someone knows a part-number/supplier for the correct pilot bushing for the Powerglide engine?
I'll search for one, and post back here if I find one.
evac34 #1230393 08/16/2017 5:10 PM
1959 Chevrolet Bel Air
L6 235 3.8L (3852cc)
Only Used For Automatic Transmission Conversion; Powerglide to Manual Transmission; 1.060 In. O.D.
Dorman 690-034
http://www.dormanproducts.com/itemdetail.aspx?ProductID=18310&SEName=690-034
Wait to hear from others to confirm this is what you need.
evac34 #1230395 08/16/2017 5:13 PM
Crusing in the Passing Lane
One could even check the dimensions of the trans and engine.
Ed
