0 members (),
129
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | So I picked up a set of amber-lens clamp-on fog lamps the other day. One of them has a 'crease-type' dent in the round, thin chromed back-casing. Is there any way to straighten it out without damaging it?
Also - does anyone know a decent place to pickup the 6v amber bulbs?
Thanks! | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 |
Harold Is a restoration ever finished? | | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | No advice for knocking out a dent in one of these thin chrome buckets? | | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | Use a sandbag to support the housing and the ball end of a ball peen hammer to gently massage the metal back into shape. You won't get it perfect, but stamped sheet metal has a "memory"- - - - -it really wants to go back to its original shape if you are careful and don't over-correct the damage. Try Ebay for the amber bulbs- - - -there are usually several available. Jerry
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | You really will never get the dent out without damage to chrome.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | Sand bag and a ball-peen, great I will give it a go. Not too worried about the chrome, just want to get it back to shape. Thanks! | | |
