| | | Forums66 Topics128,149 Posts1,056,817 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | What would be the proper way to determine if the oil pump gears need replacing ? It was determined from my other post the oil pump is a Melling 45.
Mine has 6 thousands or so of space between the oil pump gears. Would that much space cause the engine to have low running oil pressure ( Hot engine ) ?
The engine is out of the truck and I think this might be a good time to address any potential issues.
Thanks in advance. Michael...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
| | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | There has to be some space between the gears so the oil can flow between them. .006" doesn't sound like too much. What is more important is the vertical clearance between the height of the gears and the housing and the end plate. You can minimize the clearance by lapping the pump body on a piece of plate glass with a sheet of wet/dry sandpaper moistened with a little oil. Also make sure the relief valve in the pump cover is free to move and the relief spring hasn't lost its tension. Resist the urge to stretch the spring to increase oil pressure- - - - -it will go back to its original length pretty quickly.
Low oil pressure on a hot engine is usually caused by worn bearings or incorrect oil clearances. Jerry
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | The end clearance is also important on oil pumps.
Ed
| | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | panic, .006" between the teeth of the two gears where they mesh together. Vertical measurement. GearsThe clearance between the bottom of the gears and the pump housing is almost none. Pump Housing CoverJerry, the relief valve moves freely and the relief spring has good tension. I plan on hooking up a new Oil Pressure Gauge. It probably will be more accurate then the 63 year old original gauge. Could you explain incorrect oil clearances ? Thanks. Michael...
| | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | Oil clearances- - - -the amount of space between rotating parts and the bearings they run in. For instance, a connecting rod might have a clearance tolerance of .0005" to .003". The bigger the clearance, the more oil flow is required to keep the space filled with oil. The only reason oil pressure builds up at all is that the oil pump is supplying more oil than the bearings need for lubrication. If one drop of oil is supplied to a bearing every time a drop leaks out, the oil pressure would be zero, yet the bearing would get adequate lubrication because it's never allowed to run out of oil. The pressure relief valve is there to prevent a very efficient oil pump from developing a hydraulic lock and breaking the drive gear or the pump shaft. A solid stack of oil can't be compressed- - - -the engine will stall or something's going to break. The tension of the relief spring determines what the maximum pressure is supposed to be, not the capacity of the pump to develop it.
A 216 engine does not have oil pressure supplied directly to the connecting rods- - - -a stream of oil is sprayed across the oil pan in line with each connecting rod, and the dipper on the rod intersects the stream just as the rod reverses direction at the bottom of the stroke when load on the bearing is at a minimum, and a little oil gets forced into the gap between the rod and the crankshaft. The faster the crankshaft is turning, the more oil gets into the gap. At idle with very slow rod speed and low oil flow from the squirters, a trough below the rod gets filled with oil and the rods get lubed by dragging the dippers through the oil-filled trough.
The trick is to supply ALL the bearings with enough oil, as each time a little oil leaks out of a bearing and drops back into the oil pan, less pressure is available to push the rest of the oil down the line to the next place that needs lubrication. The critical parts that get pressure lubrication in most engines are the cam bearings, the main bearings, the rod bearings, and the valve system such as rocker arms, pushrods, etc. The other parts get lubed by "splash", the oil that gets thrown off the crankshaft, connecting rods, and other rotating parts. If you get the bearing clearances right, you should have plenty of oil pressure, even if the pump is slightly loose on clearance. It all works as a system- - - -just working on the pump won't give you good oil pressure. Jerry
| | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | Jerry, thank you once again for your expert explanations.
My 1960 235 was completely rebuilt in the early 1980's by my father who was also a old school mechanic. Engine has at most 10,000 miles on it.
Michael...
