0 members (),
116
0
Mod | | | Forums66 Topics128,127 Posts1,056,679 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 793 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 793 | I'm getting very close to hanging the heater back on the firewall of the '47 3100. A while back I purchased a heater gasket set from one of our preferred vendors and I now see that it's more of a foam rubber material. I don't think this stuff will hold up to the test of time...........
Has anyone purchased a true rubber set of these gaskets? If so, where did you get them? I checked Steele Rubber Company's online product catalog and didn't find them. I may just get some 1/8" sheet rubber and cut my own.
Thanks, | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Buy a sheet of the material you like and cut a new one. Those hole punch sets from harborF work great for that.
| | | | | Joined: Mar 2010 Posts: 10,296 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,296 | I would just use the foam one. When it compresses, it will fill any gaps caused by differences between the flange and the inner cowl. It should last just fine since it isn't exposed to the outside elements. I would use 3M weatherstrip adhesive to glue it to the heater flange and leave the other side of the gasket clean in case you ever need to remove the heater later. Carl
| | | | | Joined: Dec 2013 Posts: 793 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 793 | Thanks CASO and Carl,
I'll use the pre-made foam gasket for the inner cowl and cut a round rubber one for the motor through the fire wall............
Good idea on the clean gasket side too! | | |
