| | | Forums66 Topics128,012 Posts1,055,321 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2002 Posts: 53 Member | | Member Joined: Jun 2002 Posts: 53 | I need advice on a paint job. I painted the vehicle and now have spider effect showing up on some areas. I have sanded the vehicle down,cleaned it with serface cleaner and primed it with sealer primer. I then wet sanded the primer and cleaned it down again. I put the color down and in just a few minutes I would see the spider effect appear. Why is this happening? What should I do? Bob | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | i think your saying that your putting color down and its melting the primer what you have to do is spray a primer sealer down thats made for the paint your spraying you may be trying to spray laquer over enamel thats a no no you can spray enamel over laqure get a good epoxy primer sealer down first then spray enamel color hope this helps | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | napco did you get the problem worked out hopefly | | | | | Joined: Jun 2002 Posts: 53 Member | | Member Joined: Jun 2002 Posts: 53 | Yes, I did. I put on filler primer and it all worked out. Thank you. | | |
