10 members (Gdads51, Jaison, frogfarmer, rfs56trk, Woogeroo, Hotrod Lincoln, JoeDude, Jon G, TexasA&M48Truck, dt235sd), 142 guests, and 3 robots.
Topics128,035
Posts1,055,528
Members48,425
#1229552 08/11/2017 1:28 AM
1 Offline
There is a set of 461 camel hump heads for sale near me. THey are in good working condition. What is the value of a set of these heads? Also what cam/piston setup would work best with these in a mild 350 small block?
1954_3600 #1229554 08/11/2017 1:38 AM
H Online: Content
They're worth whatever the buyer and seller agree on. Most of those heads have been worn out, rebuilt, and worn out again, possibly several times. Other than impressing the mouth-breathers at a car show or building a period-correct high performance 327, they really don't have any advantage over any other cylinder head with a 64CC combustion chamber. I used to get 60CC chambers by angle milling the old 76CC low compression 350 heads. With a set of 1.92" intake valves, some 1.6" exhaust valves, and a little pocket porting, I was getting dyno numbers the camel hump heads couldn't begin to match.
If the seller wants more than about $200.00 for a set of 461 heads that haven't had new valves and guides installed, he's trying to rob you.
You'll need to use a pretty radical cam to hold the compression pressure down to a manageable level with flat top pistons in a 350- - - - -about a 280 degree duration with a .400" or higher lift. You'll have a premium-gas only engine that's very picky about how much timing advance you can run without detonation problems and piston damage.
1 Offline
i currently have a 350 disassembled that will go in my truck. I want to get my truck going before it starts getting cold out seeing as i don't have a garage to put it in. I want to do a performance engine but my budget kinda ruins that idea. Would it make sense to buy an engine and get it going and then over winter rebuild my 350 and do it how i want? I found this one fairly close to me https://minneapolis.craigslist.org/ank/pts/d/vintage-1964-chevy-small/6258592941.html
1954_3600 #1229571 08/11/2017 2:20 AM
H Online: Content
That one's priced about $100.00 or more too high unless it's needed for a numbers-correct restoration. Definitely stay far away from the single plane manifold he's offering unless you never intend to run the engine below 3K RPM. The 300 HP engine offered in 64 had the original "camel hump" heads, and the only one that was actually factory rated at 350 HP was a limited-production Corvette option. The 300 HP engines were available in the Impala body styles, beginning in 63, IIRC.
Plan on spending somewhere in the neighborhood of $4-5K, minimum, to build the kind of engine it seems like you want, and that's if you do most of the labor yourself. The round track race-winning 350's I built a few years ago sold for around $15K.
1954_3600 #1229596 08/11/2017 7:58 AM
I know nothing of your skills or finances but for what it would take to get 400hp out of a 350 you might consider an LS3 engine. It is a 327 that easily bumps the 300hp mark and gets 25mpg. I see on Epay they are selling in the 1k range and a controller harness is 12 hundred. Figure another $500 for motor mount adapters and exhaust by the time O2 sensors and bungs welded in are factored in. For 3k you can have an engine that has bukoo horsepower, idles baby butt smooth, and easily goes to the 250k mark on the odometer. Just one other route to consider.
Evan
1 Offline
That 327 comes with a points distributor, core q-jet, and he said he can swap it for an edelbrock torker intake. Eventually id like to make my truck kind of a street/strip style. It has a 4.56 rearend so something that makes more top end power would benefit from this right?
1954_3600 #1229672 08/12/2017 1:39 AM
H Online: Content
It's a worn out, obsolete engine. It's going to require a massive outlay of cash and labor to make it anything else. Give it a good cleanup and a fresh coat of Chevy Orange paint, and brag about it to people who don't know any better. The torker manifold is worse than useless without a couple of thousand dollars' worth of carburetor and valve train upgrades to make it work right, and then it will only work at RPM ranges seldom seen on the street without putting every cop in a half-mile radius in the mood to write you a handful of tickets.
1 Offline
would it make sense to sell the torker intake and purchase just a basic dual plane?
1954_3600 #1229675 08/12/2017 1:53 AM
H Online: Content
It's already got a dual plane on it, one that General Motors spent a lot of time, money and engineering expertise to build. Why mess with success?
1 Offline
Totally did not think about that.
1954_3600 #1229707 08/12/2017 6:48 AM
Take your block and build a 383?
~ Dave
Norcal Dave #1229734 08/12/2017 4:17 PM
1 Offline
it would be pretty cool to build a stroker but the truck still needs pretty much everything so i need to keep that in mind budget wise.
1954_3600 #1229751 08/12/2017 6:30 PM
H Online: Content
What's the advantage of a stroker, other than the brag factor? Most folks have no idea why they should do it (or not) or how to do it right- - - - -it's just something cool to talk about.
A stroker engine would have more torque in the lower rpm range than the same engine with a shorter stroke and larger bore
but with the same amount of cubic inches. All other things being equal, the short stroke engine will normally have a higher rpm limit.
Bob
55 Cameo 396 TH 400 with overdrive
65 Caliente conv
67 BB Caliente conv
67 Mercury 1 Ton
76 GMC 3/4 ton 454ci
84 Buick Turbo Regal
1954_3600 #1229754 08/12/2017 7:06 PM
H Online: Content
What about the rod/stroke ratio? How about lubrication boundary layer speed considerations when choosing a rod journal size for the stroker? Will the increased stroke create clearance problems between the rods, crankcase walls, and/or camshaft lobes? Inquiring minds want to know, and people without a clue will create more problems than they solve when they start tinkering with internal engine geometry.
