3 members (Otto Skorzeny, Tronman, 1 invisible), 124 guests, and 3 robots.
Topics128,142
Posts1,056,476
Members48,441
#1229338 08/10/2017 12:14 AM
I just finished up painting the cab, hood and fenders. Left is the pick up box. I have all the body work complete on the box sides and front panal and tail gate. Everything is in primer.
Question I have is should I assemble the box and then topcoat it as a unit or the individual pieces then assemble??
Thanks in advance.
Steve
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
I had mine painted in pieces.
GM painted them after assembly. They gas welded the rear cross member to the bed sides in a couple of places. It would be difficult to do that after paint.
Thanks Carl, does it need to be welded again for light duty use? Nothing will ever be in that bed.
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
I don't think there's any other attachment there than the welds, and that rear cross sill has to support the rear posts straight and square to hold the tailgate .... can be welded before paint with the rest of the bed in pieces
Fox Offline
Sstock,
I home built my bed and rear cross member. I did not weld it together and I painted under the stake pocket before spot welding. I assembled the bed and painted it as a unit. The rear bolts of the tailgate trunnions and tail light brackets hold it square by tightness. This being said however, my rear cross sill is made out of 2x6 tubing with 1/8" walls and nuts welded inside the tube, so it's VERY solid compared to original.
I suspect if you tried to use brute force tightening the bolts on a stock rear crossmember to hold the bed square that you would create dents in it.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Thanks for the responses, I think I have a plan and it includes re-welding in those places.
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
