8 members (Hotrod Lincoln, Tronman, HandyAndy, Steelonsteel, Otto Skorzeny, Charles in CA, tclederman, Bill Hanlon), 141 guests, and 3 robots.
Topics128,042
Posts1,055,501
Members48,424
#1229377 08/10/2017 2:02 AM
J M
Offline
I have a question about a 1951 GMC that I believe has a 228 in it. What is the number of quarts needed to refill the crankcase and the oil filter? Also what kind of oil do you all use?
Thanks for the information.
Jim
J M #1229385 08/10/2017 2:42 AM
Crusing in the Passing Lane
Displacement is the start of the SN stamped on machined surface by starter, 228xxx, for example.
Depending on temperature summer should be 10-40, winter could be 20-30 or 5-30 when it gets cold, depending on wear on the engine since last OH.
Ed
EdPruss #1229422 08/10/2017 12:14 PM
Ed
There is sometimes/often a preface code that indicate non-standard specs for a GMC engine (cylinder bore and/or crankshaft journal size/diameter).
J M #1229547 08/11/2017 12:56 AM
I'm partial to Kendall / Conoco Phillips, but to each their own....
I would suggest 20w50 or a 15w40spec.
Some people swear by a straight wt. 30, 40, or 50.
Funny how these engines have their own personalities and preferences ....
Use what your engine reacts the best to, change it regularly, and enjoy...
(2) 1954 3100's / foster parent - SOLD
1955.1 3100 Resto in progress
1971 GMC 2500 Custom / foster parent
1951 M37 Lawn ornament
1949 3800 Panel Resto in progress
1959 GMC 100 LB Fleetside
J M #1229585 08/11/2017 3:41 AM
J M
Offline
How much oil is needed to refill the crankcase and the filter?
Jim
J M #1229660 08/12/2017 12:39 AM
I'm unsure of what would be the average quantity, Due to installed remote filters or oil coolers, But Our 53' takes just over 5qts.
Put in 4qts and check the stick. keep filling gradually and run the engine until your satisfied with the level.
Wouldn't hurt to record the oil quantity once you find what is acceptable with a paint marker on the firewall or keep a note in the glovebox
Hope this helps,
J M #1229668 08/12/2017 1:17 AM
What year/size GMC engine do you have?
The GMC 6 cylinder engines often held more oil than the Stovebolt Six engines held.
Do you have a GMC owners manual or a GMC Maintenance Manual?
J M #1229669 08/12/2017 1:25 AM
My 1950 GMC 228 takes 8qts and that's what's the GMC owner manual says too.
J M #1229671 08/12/2017 1:35 AM
showkey,
My 54/55 GMC 270 engine also hold 8 quarts plus 1 quart for the oil filter.
Last edited by tclederman; 08/12/2017 10:23 AM. Reason: corrected. quarts, I think
J M #1229688 08/12/2017 3:09 AM
All GMC oil pans I have seen appear to be the same shape, perhaps some oil dipsticks are different?
Ed
J M #1229695 08/12/2017 3:39 AM
J M
Offline
Thanks for the information. I an just trying to find the information for a friend,. I know the truck is a 1951, and I think it is a pickup, but i have never seen it. I am sure your responses will help him a lot
again thanks
Jim
EdPruss #1229738 08/12/2017 4:55 PM
Ed
Most likely correct for 228, 248, and maybe 270.
However, early 302s had "deep sump" oil pans. And, maybe 270/302 on COEs had different oil pans (they had different valve covers).
Spanky and Crenwelge would know.
J M #1229800 08/13/2017 1:50 AM
Military 302's had two section, deep pans.
Ed
J M #1229801 08/13/2017 1:52 AM
I think my 54/55 350 COE's 270 has a similar pan.
