0 members (),
108
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I might as well try to make something useful as I practice my welding. It's not done yet, but close. VISE STAND LINK | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | I would be scared to death to put anything heavy in a heavy vise on top of such a small wheel. Afraid it would fall over (top heavy) and break something important like my foot. JMOðŸ›
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I would be scared to death to put anything heavy in a heavy vise on top of such a small wheel. Afraid it would fall over (top heavy) and break something important like my foot. JMO🛠I can stack heavy weights on that wheel. That would help. I don't want to make it really heavy ALL THE TIME or it will be very difficult to move ALL OF THE TIME. Plus, if the vise proves to be too heavy, I'll simply bolt my grinder on top instead. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | That would make and excellent grinder stand. I have one similar in dimensions as yours and it is very handy to work on and is easy enough to slide it out of the way . Nice welds too, BTW. I am guessing that you used a fair amount of filler rod on the top piece. If you would have cut all of the pieces for the top completely through instead of partially and folding them (very cool way to do it BTW), you could have held the pieces together with corner magnets and welded the entire top without any filler wire whatsoever. It is referred to as fusion welding. The guy who I buy my consumables from taught me that trick. Carl
| | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | I love how you used that old vise to build its new platform for it! | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | Try this- - - -go to a truck repair shop and ask them to sell (or give) you a discarded brake drum. Most 18-wheeler drums are cast iron, 16" in diameter and they weigh around 100 lbs. apiece. I'm in the process of building a forge from two of them, connected by a piece of 4" diameter black steel pipe. The bottom drum serves as a base, and the top will be lined with fire brick and refractory cement with a piece of 3/4" pipe through the middle with an air diffuser made from a pipe cap with several holes drilled in it. The air for the forge will come from a recycled electric leaf blower connected to the bottom of the 3/4" pipe.
A similar setup would work as your vise base, and it can be moved around the shop by tilting and rolling it. You'll need to weld a steel disc onto the upright and bolt it to the drum, as welding steel to cast iron is a real challenge. Jerry
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I made the top piece by cutting part way through the metal, folding, and then welding without filler rod.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Nice stand, I like the detail at the bottom to bolt it to the wheel.
As others have said a big brake drum makes a nice base for similar stands.
I make a vise stand from a 48 2 ton rear drum and a semi truck axle shaft. The axle shaft lined up with two holes and just bolted into the drum with 1/2" bolts. On top I trimmed it to length and welded a plate to bolt the ~4" vice on. It's quite useful and as Jerry said easily moved by tipping it and rolling. However it's not a perfect vice stand, it could be a lot heavier. Just using a hacksaw on something and it wiggles and wobbles. Has it's uses and portable is good, but not to be substituted for a vice bolted to a real solid stable or massively heavy stand.
Grigg | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | A couple of 80-lb. bags of quick-mix concrete in the brake drum can add some stability, also. Jerry
| | | | | Joined: Oct 2005 Posts: 4,250 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,250 | I would worry about the current configuration being a little top heavy. | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I would worry about the current configuration being a little top heavy. Yes, I share your concern. I plan to add weight to the base. I also plan to make the "table top" so it will slide about 6" so that if I have anything BIG inside the jaws I can easily center the vise over the post. If it proves to be too "tippy" then I'll just use it for my bench grinder. I can't lose. | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | I think I just figured out a really good, totally safe use for widowmaker wheels!- - - - - - -bench grinder and/or vise bases! Jerry
| | | | | Joined: Aug 2001 Posts: 3,591 Moderator | | Moderator Joined: Aug 2001 Posts: 3,591 | Jerry You forgot another use. Anvil stand base!
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Oct 2005 Posts: 4,250 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,250 | Sign holder. Plow discs do equally as well. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: Oct 2005 Posts: 4,250 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,250 | A lathe and a stove? Machine and cook? | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | That's cool Grigg, I like that on many levels. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I'm waiting for Lugzy to post, "I just got back from the emergency room." "I guess I shoulda put the bench grinder on it." Be forewarned, and I am serious. When I utter something like that aloud, it has an extreme likelihood of coming true. (I don't know if it works the same if I merely post it.) Carl
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I'm waiting for Lugzy to post, "I just got back from the emergency room." "I guess I shoulda put the bench grinder on it." Be forewarned, and I am serious. When I utter something like that aloud, it has an extreme likelihood of coming true. (I don't know if it works the same if I merely post it.) Carl I just posted more about the VISE STAND on my BLOG. I'm looking for ideas about how to connect this #50 weight to the wheel. LINK HEREJay | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | Just drill a few holes in the weight and bolt it to the underside of the wheel., assuming it will fit inside the barrel area and still allow the bead area to sit flat on the floor. Jerry
| | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | Don, I've got a big hickory stump to mount the anvil onto. It's about 18" in diameter and 24" tall. Jerry
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Plow discs do equally as well. Save those for me please. I use them to make campfire discadas (big fry pan). Brad Wrench Fetcher, PhD | | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | Jay;
I took a look at your vise/tool stand. I have found that it will be less "tippy" if you turn the wheel upside down. The back spacing of the wheel lowers the pivot point of the post. Your 50 pound weight will really do the trick.
SimS | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Wheel Up or down makes no difference. Height of post above floor is all that affects leverage and stability. We'll also size of base on the floor, which is same either side of a wheel.
I suppose slightly lower center of gravity with dish down, but it's not a heavy wheel to make a lot of difference. | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Jay;
SimS The back side of the wheel is very rusty, so I put the nicer side up. The wheel offset is almost zero. | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Just drill a few holes in the weight and bolt it to the underside of the wheel., assuming it will fit inside the barrel area and still allow the bead area to sit flat on the floor. Jerry Cutting a square hole in the middle and sliding the 50# weight over the post was PLAN A but was too much effort. Your suggestion was PLAN B and the one I used. See photos in the link. VISE Fabrication plus VIDEONotice in the video how I lose MY BALANCE but the VISE STAND is rock solid. I was NOT DRINKING, and NO . . . . . I will NOT show you my TIG welds. Not very proud of them. Gotta keep practicing. Jay
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I have several large vices on heavy tables. My largest one is a Wilton mounted on a table made out of 1" sheet steel about 4'x8'. We brought the whole thing into the shop many years ago with a forkllift. A vice has to be securely anchored to be of any use. Occasionally I need a vice at my house. I bought a Wilton receiver hitch vice. It is made in China, but its ok for around the house. http://www.wiltontools.com/us/en/s/atv-all-terrain-vise/As for 16½x7 brake drums. They will will weld. We have all sorts of things made out of them. With scrap iron so cheap, we give them away. They weigh a little over 100lbs and have about a 17" footprint. That is stable enough for something like a grinder, but I'm not so sure about mounting a vice on one and expecting to do anything with the vice. | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | This vise is only one of three that I own. The main reason I want it on a portable stand is so I can quickly clamp something OUTSIDE my shop for grinding. It is only intended for light duty work. I have shop vises mounted to heavy tables inside my shop already. | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Pretty much done with this project. Chopped it 3" shorter for comfort. I added a round disc of plywood to keep stuff I drop from falling inside the wheel. Soon I'll make a grinder stand. Vise Stand LINKJay
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What diameter and thickness of plywood? I have done this with stands for various purposes, and I have had no problems | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Oops, My plywood was the base, to increase stability. | | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Nice Jay....how are you and that Tig getting along?
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | What diameter and thickness of plywood? I have done this with stands for various purposes, and I have had no problems The plywood is probably 1/4" or 3/8". I had a piece just the right size. The diameter of the disc was just over 16.5". It was easy to use a jigsaw to cut a square center hole, slide it over the post and trace the wheel from below. Otherwise I would have just used a large piece of cardboard. I'm cheap. | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Nice Jay....how are you and that Tig getting along? I've not had much time to practice. I need to try some more. I'll try some when I build my grinder stand. | | |
