0 members (), 109 guests, and 3 robots.
Topics128,062
Posts1,055,854
Members48,428
#1229140 08/08/2017 11:21 PM
Does anyone know a good way to clean out the draft tube? Mine has some nasty stuff in it and I would like to get it out. Is there a cleaner you can use? Thanks
nak1954 #1229142 08/08/2017 11:32 PM
It depends how thick/heavy the caked grease/goop is.
Some people burn them out.
Some people soak in kerosene.
Some people take off the "cap" and clean the parts.
Some people do a combination of the above.
The fibrous contents is supposedly horse hair.
nak1954 #1229143 08/08/2017 11:37 PM
Is was thinking of putting it in a parts cleaning solvent. Will the top cap go back on if you take it off? It looks pressed on.
nak1954 #1229415 08/10/2017 11:35 AM
I wouldn't pop the cap. Soaking it is your best option. I would use a eco-friendly degreaser. the only reason I suggest the eco-friendly is I assume it would be less caustic in case the fibrous contents is in fact horse hair.
Dave from Northern Kentucky
My 54 3100
nak1954 #1229522 08/10/2017 10:35 PM
Crusing in the Passing Lane
A piece of wire or suitable stick with a rag tied on the end should do a suitable job.
Ed
