| | | Forums66 Topics128,074 Posts1,055,910 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | My nephew has a '71 Mustang Mach 1 he's starting to restore and he wants to paint details like the Mach 1 Logo on the car, instead of applying decals, before the final clear coat.
I'm a graphic designer and use a Mac computer ... real familiar with Photoshop, etc. ... but does anyone know what software painters use to create stencils or where I can learn the ropes about the latest techniques of this part of the painter's toolkit?
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I got no clue, but I have a buddy w/a Camaro, they installed the decals on the fresh paint then clearcoated over them-has kept the decals from fading, also no polish buildup at the decals. Brian | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Man Alan, I'd like to know this also. I'v seen the car builder TV shows use stencils and I’m sure there are plotters that can cut stencils. I’m thinking some place that does graphic design would have a stencil cutter that a Photoshop file could drive. I would like to use them on all the repainting, i.e., emblems “CHEVROLET”, valve cover “Thrift-Master”, etc. It would look much more original than a decal. The guys that did the blue prints used to cut them down at work, but we were under contract from the government and you can’t get away with ‘G’ job now-a-days. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I also know of folks buying the decals & using them to make stencils for painting. Brian | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | buddy of mine that's a sign painter uses the same software and cutter that he uses to do vinyl letters
Bill | | | | | Joined: Apr 2005 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 37 | Most sign painters, including myself use Corel Draw, Signlab,Gerber and Flexisign software to design and reproduce logos etc. Corel is a great vector and bitmap program but has its drawbacks with certain vinyl cutters.
Alan, your probably familar with adobe illustrator. You can draw it in that program as well and then take it to a sign shop for them to cut a paint stecil using a paint mask vinyl.
Let me know if you need more details.
Rob | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Thanks everyone.
I wouldn't want decals on any vehicle even with clear coat, they still look "obvious" to me, whereas a painted logo looks top-shelf, you know?
Thanks, Rob -- I hadn't thought about going to a sign shop. That just might be the answer.
I have Illustrator and Photoshop ... I know I can do any type of graphics but the stencil is what I was trying to get to and the machines that make them are like $5000! Sign shops buy those machines, so I guess I'll have to visit a sign shop and see what they would charge for a stencil.
Cool!
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Aug 2006 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 112 | The easiest way is with a vinyl cutter, looks like a drafting plotter, but with a razor instead of a inkjet. They use a software called Lxi Pro. Look on signwarehouse.com might help. Don't know what this stuff costs
64 & 66 GMC long fleetside 4x4 Cartwright, OK
| | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | They start at $700 and go up to $10,000
Better to visit a sign shop and let them do it for you!
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | | | |
