0 members (), 93 guests, and 2 robots.
Topics128,167
Posts1,057,021
Members48,458
Hey Bolters,
I am planning on installing a 3:55 rear end in my 46 1/2 ton (currently have the std 4:11). Are there speedometer gears available for the 3:55 ratio? I have my transmission apart, so it would be the best time to change, if available. I have also read about adapters that go inline with the speedometer cable.
Thanks.
Larry
Larry
46 Chevy 1/2 ton stake - family truck for 78 years
USAF 75-81
Good luck finding gears, Larry
I use an "inline" adapter on my Suburban. The company that made it for me seems to be gone.
You calibrate/calculate the ratio with a GPS or by measuring miles on an interstate.
Maybe someone who has had one made recently will post information?
?? http://www.clarkbrothers.net/ratio_adapters.html. ??
Y
yar Offline
Y Offline
Good morning Larry.
I did the same conversion on my '36 Chevy pickup and then the speedometer and odometer were off by 17%.
A 17% overdrive adapter from Mr. Speedometer in Canada solved that problem. His adapter goes on the back of the speedometer head.
The '36 is much more pleasant to drive with the 3.55 gears.
Ray
Thanks for the tip Ray. I will contact your source.
Larry
USAF 75-81
Crusing in the Passing Lane
Or one can just remember your speedo is 11% fast, or whatever, pretty simple.
Ed
Google PATC transmission parts, They can make you an adapter. I had mine made a couple of years ago and it works great for a sm420 with 3:55's. I think it was around $80. They are in Louisiana, Tom
Anybody ever take one of these apart? I was looking at the gear ratios available from Clark Bros and it seems like they can't be getting these by changing tooth counts. Do they just use 2 wheels of different diameter? Just wondering.
They are toothed gears, positive engagement.
Ed
Thanks for the info delwrench. I will check them out.
Larry
USAF 75-81
Larry, I am planning the same 3:55 upgrade in my 46 1/2 ton as well just south of you in Northeast Florida.
Good info to know regarding the speedometer. Good luck!
Todd
1946 Chevrolet 1/2-ton
More pix on Photobucket
Very nice truck Todd!
Hopefully, in six months or so mine will look similar (other than I have a stake bed). Updating everything mechanical first, then on to paint and body.
Larry
USAF 75-81
Thank you Sir! Good luck and keep us posted!
