8 members (Gdads51, frogfarmer, Bill Hanlon, LAROKE, gswbbc, Forty9, 48jim1ton, Hotrod Lincoln), 107 guests, and 0 robots.
Topics128,043
Posts1,055,540
Members48,425
#1228737 08/06/2017 4:51 PM
I might as well try to make something useful as I practice my welding. It's not done yet, but close.
VISE STAND LINK
Lugnutz #1228743 08/06/2017 5:31 PM
I would be scared to death to put anything heavy in a heavy vise on top of such a small wheel. Afraid it would fall over (top heavy) and break something important like my foot. JMO🛠
I can stack heavy weights on that wheel. That would help. I don't want to make it really heavy ALL THE TIME or it will be very difficult to move ALL OF THE TIME.
Plus, if the vise proves to be too heavy, I'll simply bolt my grinder on top instead.
Lugnutz #1228824 08/07/2017 2:50 AM
That would make and excellent grinder stand. I have one similar in dimensions as yours and it is very handy to work on and is easy enough to slide it out of the way .
Nice welds too, BTW.
I am guessing that you used a fair amount of filler rod on the top piece.
If you would have cut all of the pieces for the top completely through instead of partially and folding them (very cool way to do it BTW), you could have held the pieces together with corner magnets and welded the entire top without any filler wire whatsoever. It is referred to as fusion welding. The guy who I buy my consumables from taught me that trick.
Carl
Lugnutz #1228847 08/07/2017 4:07 AM
Fox Offline
I love how you used that old vise to build its new platform for it!
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Lugnutz #1228855 08/07/2017 4:55 AM
H Online: Content
Try this- - - -go to a truck repair shop and ask them to sell (or give) you a discarded brake drum. Most 18-wheeler drums are cast iron, 16" in diameter and they weigh around 100 lbs. apiece. I'm in the process of building a forge from two of them, connected by a piece of 4" diameter black steel pipe. The bottom drum serves as a base, and the top will be lined with fire brick and refractory cement with a piece of 3/4" pipe through the middle with an air diffuser made from a pipe cap with several holes drilled in it. The air for the forge will come from a recycled electric leaf blower connected to the bottom of the 3/4" pipe.
A similar setup would work as your vise base, and it can be moved around the shop by tilting and rolling it. You'll need to weld a steel disc onto the upright and bolt it to the drum, as welding steel to cast iron is a real challenge.
52Carl #1228862 08/07/2017 10:26 AM
I made the top piece by cutting part way through the metal, folding, and then welding without filler rod.
Lugnutz #1228879 08/07/2017 1:25 PM
Nice stand, I like the detail at the bottom to bolt it to the wheel.
As others have said a big brake drum makes a nice base for similar stands.
I make a vise stand from a 48 2 ton rear drum and a semi truck axle shaft. The axle shaft lined up with two holes and just bolted into the drum with 1/2" bolts. On top I trimmed it to length and welded a plate to bolt the ~4" vice on.
It's quite useful and as Jerry said easily moved by tipping it and rolling.
However it's not a perfect vice stand, it could be a lot heavier. Just using a hacksaw on something and it wiggles and wobbles. Has it's uses and portable is good, but not to be substituted for a vice bolted to a real solid stable or massively heavy stand.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Lugnutz #1228885 08/07/2017 2:19 PM
H Online: Content
A couple of 80-lb. bags of quick-mix concrete in the brake drum can add some stability, also.
Lugnutz #1228956 08/08/2017 12:20 AM
I would worry about the current configuration being a little top heavy.
MNSmith #1228961 08/08/2017 12:48 AM
Yes, I share your concern. I plan to add weight to the base. I also plan to make the "table top" so it will slide about 6" so that if I have anything BIG inside the jaws I can easily center the vise over the post.
If it proves to be too "tippy" then I'll just use it for my bench grinder. I can't lose.
Lugnutz #1229175 08/09/2017 1:48 AM
H Online: Content
I think I just figured out a really good, totally safe use for widowmaker wheels!- - - - - - -bench grinder and/or vise bases!
Lugnutz #1229183 08/09/2017 2:17 AM
Moderator
Moderator
2 Offline
You forgot another use.
Anvil stand base!
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Lugnutz #1229200 08/09/2017 3:47 AM
Sign holder. Plow discs do equally as well.
Lugnutz #1229238 08/09/2017 12:45 PM
Here's how I use widow maker wheels
https://goo.gl/photos/mSb3UHT89ppk6g7A9
---All pictures---
Lugnutz #1229240 08/09/2017 1:12 PM
A lathe and a stove? Machine and cook?
Grigg #1229335 08/10/2017 12:12 AM
That's cool Grigg, I like that on many levels.
Lots more pictures
Lugnutz #1229367 08/10/2017 1:29 AM
I'm waiting for Lugzy to post, "I just got back from the emergency room." "I guess I shoulda put the bench grinder on it."
Be forewarned, and I am serious. When I utter something like that aloud, it has an extreme likelihood of coming true. (I don't know if it works the same if I merely post it.)
Carl
52Carl #1229369 08/10/2017 1:33 AM
Carl
I just posted more about the VISE STAND on my BLOG. I'm looking for ideas about how to connect this #50 weight to the wheel.
LINK HERE
Jay
Lugnutz #1229614 08/11/2017 1:42 PM
H Online: Content
Just drill a few holes in the weight and bolt it to the underside of the wheel., assuming it will fit inside the barrel area and still allow the bead area to sit flat on the floor.
Lugnutz #1229616 08/11/2017 1:50 PM
H Online: Content
Don, I've got a big hickory stump to mount the anvil onto. It's about 18" in diameter and 24" tall.
MNSmith #1229622 08/11/2017 2:32 PM
U
U Offline
Save those for me please. I use them to make campfire discadas (big fry pan).
Brad
Wrench Fetcher, PhD
Lugnutz #1229712 08/12/2017 11:42 AM
Jay;
I took a look at your vise/tool stand. I have found that it will be less "tippy" if you turn the wheel upside down. The back spacing of the wheel lowers the pivot point of the post. Your 50 pound weight will really do the trick.
SimS
Lugnutz #1229715 08/12/2017 11:56 AM
Wheel Up or down makes no difference.
Height of post above floor is all that affects leverage and stability. We'll also size of base on the floor, which is same either side of a wheel.
I suppose slightly lower center of gravity with dish down, but it's not a heavy wheel to make a lot of difference.
---All pictures---
SimS #1229790 08/13/2017 1:12 AM
Originally Posted by SimS
Jay;
SimS
The back side of the wheel is very rusty, so I put the nicer side up. The wheel offset is almost zero.
Cutting a square hole in the middle and sliding the 50# weight over the post was PLAN A but was too much effort. Your suggestion was PLAN B and the one I used. See photos in the link.
VISE Fabrication plus VIDEO
Notice in the video how I lose MY BALANCE but the VISE STAND is rock solid. I was NOT DRINKING, and NO . . . . . I will NOT show you my TIG welds. Not very proud of them. Gotta keep practicing.
Jay
Lugnutz #1229987 08/14/2017 6:56 AM
I have several large vices on heavy tables. My largest one is a Wilton mounted on a table made out of 1" sheet steel about 4'x8'. We brought the whole thing into the shop many years ago with a forkllift. A vice has to be securely anchored to be of any use. Occasionally I need a vice at my house. I bought a Wilton receiver hitch vice. It is made in China, but its ok for around the house. http://www.wiltontools.com/us/en/s/atv-all-terrain-vise/
As for 16½x7 brake drums. They will will weld. We have all sorts of things made out of them. With scrap iron so cheap, we give them away. They weigh a little over 100lbs and have about a 17" footprint. That is stable enough for something like a grinder, but I'm not so sure about mounting a vice on one and expecting to do anything with the vice.
Lugnutz #1229995 08/14/2017 11:33 AM
This vise is only one of three that I own. The main reason I want it on a portable stand is so I can quickly clamp something OUTSIDE my shop for grinding. It is only intended for light duty work. I have shop vises mounted to heavy tables inside my shop already.
Lugnutz #1232012 08/25/2017 9:09 PM
Pretty much done with this project. Chopped it 3" shorter for comfort. I added a round disc of plywood to keep stuff I drop from falling inside the wheel.
Soon I'll make a grinder stand. grin
Vise Stand LINK
Jay
Lugnutz #1232030 08/25/2017 11:32 PM
What diameter and thickness of plywood? I have done this with stands for various purposes, and I have had no problems
Lugnutz #1232031 08/25/2017 11:34 PM
Oops, My plywood was the base, to increase stability.
Lugnutz #1232032 08/25/2017 11:35 PM
Nice Jay....how are you and that Tig getting along?
Allen
1974 Stingray Corvette
tclederman #1232034 08/25/2017 11:39 PM
The plywood is probably 1/4" or 3/8". I had a piece just the right size. The diameter of the disc was just over 16.5". It was easy to use a jigsaw to cut a square center hole, slide it over the post and trace the wheel from below. Otherwise I would have just used a large piece of cardboard. I'm cheap.
Allen Lane #1232037 08/25/2017 11:44 PM
I've not had much time to practice. I need to try some more. I'll try some when I build my grinder stand.
Moderated by  MNSmith
