2 members (dinosoar, 52Carl),
82
Mod | | | Forums66 Topics128,127 Posts1,056,677 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2016 Posts: 268 'Bolter | | 'Bolter Joined: May 2016 Posts: 268 | Hi everyone.Was hoping somebody out there in northern IL/chicago area has some recommendations on a quality machine shop you may have used and were happy /satisfied with their work. I have some machining to do on the 49 gm and wanted to see if someone knew a superior shop. Phone book has dozens but I'm flying blind never having used any of them. Thanks in advance for any. Leads. John. S/W burbs 1949 gmc 1-ton | | | | | Joined: May 2009 Posts: 85 'Bolter | | 'Bolter Joined: May 2009 Posts: 85 | Dons, in Kenosha, has been there forever,
Powersource engines in Fox Lake IL I used to know Ray pretty good but sort of lost contact
Antioch Automotive can do most stuff.. Antioch IL
1949 3100
| | | | | Joined: May 2016 Posts: 268 'Bolter | | 'Bolter Joined: May 2016 Posts: 268 | Thanks for the suggestions . 1949 gmc 1-ton | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Auto Machine in St. Charles. dg
Denny G Sandwich, IL
| | | | | Joined: Aug 2009 Posts: 196 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 196 | I used Auto Machine in St Charles all during the 70s-80s. Tell them Archie said Hi! | | | | | Joined: May 2016 Posts: 268 'Bolter | | 'Bolter Joined: May 2016 Posts: 268 | Thanks again for the suggestions. Will give them a call 1949 gmc 1-ton | | | | | Joined: Feb 2010 Posts: 82 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Feb 2010 Posts: 82 | | | |
