7 members (Lightholder's Dad, Otto Skorzeny, KEVINSKI, lumbersawyer, BC59, tclederman, 1 invisible), 67 guests, and 1 robot.
Topics128,154
Posts1,056,853
Members48,456
#1228156 08/02/2017 9:38 PM
looking to install 3 point seat belts to my 1959 3600 apache. Has anyone bought them and installed them? It looked like i would have to weld something in for the shoulder strap.Pictures would be great.
U
U Offline
Pictures from my 55.2 seatbelt & lap belt install.
I will have to find my write-up on this install, but it was a breeze. Lots of help from the late Cletis, if I remember correctly.
I'll also have to find my notes on where I bought them.
Brad
Wrench Fetcher, PhD
Fox Offline
Here is Deve's write up on an install on an AD truck. It's not a Task Force but I'm sure you'll find it useful. I used his site on my install.
http://devestechnet.com/Home/SeatBelts
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
V
VEW Offline
V Offline
I wanted to change out the seats in my 41 anyway, so I installed ones from a Tahoe that had them build in.
~ Victor
1957 3100 - moved on
Thanks for the Info
I've put Juleano's (sp) 3-point seat belts in two TF trucks. Took 45 minutes to install each time. The shoulder point nut is welded to a backing plate that you tape to a stick or rod and slide up from the bottom to where you have your hole drilled. Once the bolt is threaded into the nut on the backing plate pull the rod out and you're done. No need to cut or weld anything, the backing plate has rounded edges so it won't tear and pull out in a wreck. To figure out how high to mount the shoulder bolt, sit in a modern vehicle and see where it is to your shoulder...3-4" above?
I mounted the floor brackets in the raised channel that's behind the seat. If memory serves me I had to reshape the bracket to fit snug in the channel, I did not cut it to fit.
That's it...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
