| | | Forums66 Topics128,149 Posts1,056,819 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 6 New Guy | | New Guy Joined: Apr 2016 Posts: 6 | looking to install 3 point seat belts to my 1959 3600 apache. Has anyone bought them and installed them? It looked like i would have to weld something in for the shoulder strap.Pictures would be great. | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Pictures from my 55.2 seatbelt & lap belt install. I will have to find my write-up on this install, but it was a breeze. Lots of help from the late Cletis, if I remember correctly. I'll also have to find my notes on where I bought them. Brad Wrench Fetcher, PhD | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Here is Deve's write up on an install on an AD truck. It's not a Task Force but I'm sure you'll find it useful. I used his site on my install. http://devestechnet.com/Home/SeatBelts | | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 | I wanted to change out the seats in my 41 anyway, so I installed ones from a Tahoe that had them build in.
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Apr 2016 Posts: 6 New Guy | | New Guy Joined: Apr 2016 Posts: 6 | | | | | | Joined: Mar 2004 Posts: 6,228 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,228 | I've put Juleano's (sp) 3-point seat belts in two TF trucks. Took 45 minutes to install each time. The shoulder point nut is welded to a backing plate that you tape to a stick or rod and slide up from the bottom to where you have your hole drilled. Once the bolt is threaded into the nut on the backing plate pull the rod out and you're done. No need to cut or weld anything, the backing plate has rounded edges so it won't tear and pull out in a wreck. To figure out how high to mount the shoulder bolt, sit in a modern vehicle and see where it is to your shoulder...3-4" above? I mounted the floor brackets in the raised channel that's behind the seat. If memory serves me I had to reshape the bracket to fit snug in the channel, I did not cut it to fit. That's it... Mike B  | | |
