0 members (), 254 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#1227876 07/31/2017 11:18 PM
My 51 is basically stock and I cannot always pay attention to it like I should. Thus, it has become a maintenance nightmare. My solution
is to take out the 261, pull off the body, put it on a modern chassis and plop a LS3 in it. Besides the people on TV, does anyone know a
directory for car builders (Carolinas).
1951 Chevy 3100 5-window
261 cu in, 348 Head, Split Fenton Exhaust
Offy with Dual Weber 2 Bbl Carbs
51bowtie #1227878 07/31/2017 11:22 PM
Good luck, 51 bowie.
What year 261 engine?
What sort of nightmare maintenance was the 261 causing you to do?
If you have made up your mind, you might want this thread to be moved to The HiPo Shop forum.
tclederman #1227879 07/31/2017 11:29 PM
Its a 59 (3759365) 261 with a 56 (3836848) head. I have split exhaust on it
and an Offy 2 single barrel intake. I currently have twin Carter YF's . The Carbs leak,
the oil leaks, the water leaks and I don't have the energy anymore to track it all
down. And, it sits for long periods.
51bowtie #1227887 08/01/2017 12:05 AM
Do you have an insulator under each Carter?
How are you heating the Offenhauser intake?
You'll need a LOT of energy and a LOT of $$$ in order to plop an LS3 onto a different chassis. This does not sound like an easy solution.
I had two Rochesters on a Offenhauser water-heated 261, with no problems since 1997 (now owned by a friend).
51bowtie #1227899 08/01/2017 1:18 AM
Changing rear ends requires cutting off spring perches and welding on new ones in the location you need. Get a GM as close to the width as your original such as 70's Camero/Firebird. It's doable.🛠
Yes I have insulators under the carbs. Started out heating the Offy with exhaust gas then changed to water.
51bowtie #1227946 08/01/2017 2:56 PM
Crusing in the Passing Lane
Chevy 6's are as simple, low maintenance as they get. Perhaps it might be well for you to read-up or take a maintenance class at the local college. Plus, it is all already paid for.
Ed
51bowtie #1227955 08/01/2017 4:00 PM
Excellent suggestion from Ed. thumbs_up
Stovebolt Engine History 101, most likely (an upper level elective)? ohwell
51bowtie #1228056 08/02/2017 3:25 AM
There are guys out there who are waiting for the day where they can find a workable 261 for one of these trucks. You don't need any more power than that with an otherwise stock truck.
