0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#122743 11/01/2006 8:03 PM
Is it absolutely necessary to paint an engine with heat resistant paint?
Roger
http://www.flickr.com/photos/45469713@N00/?saved=1
#122744 11/01/2006 8:41 PM
rogpatt,
In my ongoing attempt to say anything about everything, I will say this. The generic rattle can paint is good to about 120 degrees.
I would imagine most parts of the engine get that warm, as the coolant temp usually runs more than this.
If one were going to take the time and energy to paint the engine, and with so many colors available in 'engine paint', why not use it.
I think most engine paints go to 300 degrees, and would be fade free up to this temperature.
That's my take on the subject. grin
Stuart
#122745 11/01/2006 9:45 PM
Only if you want the paint to stay on the engine.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
#122746 11/01/2006 9:45 PM
OR... you could do a test on some "regular" paint, and report the results back to us... smile
Another quality post.
Real Trucks Rattle
#122747 11/01/2006 10:10 PM
I would like to rest the engine but I already pulled it from the truck.
Roger
#122748 11/01/2006 11:30 PM
huh?
#122749 11/02/2006 2:36 AM
Correction! I would like to "test" a part of the engine wiht standard paint but I alredy pulled it off the frame! grin
Roger
#122750 11/02/2006 3:06 AM
i painted my engine with rattle can paint, it stayed good for many years until i had an overheating problem. temp guage went to 250 degrees and most of the paint on the block vaporized. valve cover still looks painted,very little left on the block.
i love my dog's 1965 suburban.
#122751 11/02/2006 4:33 AM
Regular bc/cc paint works great. You can match the color to your body also if you want.
#122752 11/02/2006 4:57 AM
carryall jerry,
Did you say "very little left on the block"...after a over temp like that, it might be "very little left of the block". wink
Stuart
#122753 11/02/2006 12:36 PM
I am not by any means a painter. So educate me a bit! What does bc/cc mean!
Thanks, Roger
Roger
#122754 11/02/2006 2:22 PM
Stea,
Never mind I figuered out what bc/cc means!
Have you used bc/cc on a engine block yourself?
I called a local paint store and they said you have to use a special hardener. Which runs about $40.
Roger
Roger
#122755 11/02/2006 2:28 PM
Quote
Originally posted by atomarc:
carryall jerry,
Did you say "very little left on the block"...after a over temp like that, it might be "very little left [b]of
the block". wink
Stuart [/b]
No, it still ran decent,remember its an old chevy.!
#122756 11/02/2006 6:35 PM
Yep, used the same paint on my motor as my truck. It still looks brand new. I thought it would burn off around the exhaust ports but it hasnt.
Yea, bc/cc is a little expensive but well worth it. You need the base color, reducer, clear and activator.
#122757 11/02/2006 6:44 PM
Im going to give it a shot!
I will let you guys know how it turns out!
Roger
