8 members (wvstovebolt, 1955 1 Series, SuperSport, ‘37ChevyPU, tclederman, Gray_Ghost, Cletus1950, 78buckshot),
49
Mod | | | Forums66 Topics128,129 Posts1,056,697 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | Hi, Does any one know the diameter of the wiper motor shafts on a trico motor off a 1949 chevy 3800 truck? I can't keep the original type spring clips on, So I think I will try a push clip or something.
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If the rubber bushings on the arms are to fat they will work the clips right off.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2010 Posts: 10,296 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,296 | Make sure nothing is bent, putting undue force on the spring retainer while the lever is moving.
