3 members (Hotrod Lincoln, DadsFirstPickup, Otto Skorzeny), 137 guests, and 4 robots.
Topics128,148
Posts1,056,810
Members48,454
I have a 1978 C65, single axle dump truck, and I wonder if there is any way to identify whether the
engine is a 366 or a 427. This truck is one of the years where they were changing the format of the codes,
and the engine type is not listed on the tag.
I don't know if this information is helpful, but the engine is a light blue colour, and is coupled to a 5 spd transmission
and a two speed rear axle.
Bob
55 Cameo 396 TH 400 with overdrive
65 Caliente conv
67 BB Caliente conv
67 Mercury 1 Ton
76 GMC 3/4 ton 454ci
84 Buick Turbo Regal
Is your truck American or Canadian made?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
3B Offline
Hy BigBlockCameo, my newest service manual is a 1977, it says the standard engine for a CE65 is a 366 with the option being a 427. There is supposed to be an engine identification plate on the front upper side of the right hand valve cover, 366 - GM114-366 CID, 427 - 114- 427 CID, hope that helps.
H Online: Content
There should be a letter/number sequence stamped (not cast) on a machined pad on the front of the engine block just ahead of the passenger's side cylinder head. The last few digits in the sequence which are usually letters, will identify the engine size and possibly the year it was manufactured. There are several engine number conversion websites on the internet.
1978?
BBC,
What is the casting number? There were several numbers through the 60s, 70s,etc. for the truck tall deck blocks. That might help to narrow it down. Also is there a RPO sticker on the truck? That may have a code for what was originally installed.
SimS
