2 members (J Lucas, delky),
173
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 14 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 14 |
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Since you have 5/10 bolt pattern, look on modern trucks with that pattern, 94/95 GMC P3500 for one.
Ed
| | | | | Joined: Aug 2009 Posts: 14 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 14 | It's a torsion bar front end, I doubt anyone makes a disc brake set up for this suspension. It may be worth a try to try and adapt 94/95 GMC P3500 front discs on my spindles, hopefully. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | As Ed suggest. Check out those axles discussed in this tech tip. https://www.stovebolt.com/techtips/bigbolts/p30swap/Your tape measure will guide you, but I'm thinking might be able to swap a newer front axle as is, no narrowing? Rear axle is an easy swap if desired. If swapping entire front axle is not measuring up then, or may be easier to start with, to swap just spindles, hubs, and brakes. That is discussed here: https://www.stovebolt.com/ubbthread...4-1-1-5-and-2-ton-trucks.html#Post725027Looks like it has 19.5" tires already, which is a nice upgrade from the tube type 18" or 20" it may have had original. Only thing better might be 22.5" but they're hard to find. Grigg (Edit) Missed the torsion bar bit while typing up my reply. May still be able to swap newer spindles or possibly entire axle and suspension
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | When you find a donor truck, make sure to get the donor hydroboost unit while at it, might also get powersteering unit if it can be used as well as power steering/hydroboost pump.
Ed
| | | | | Joined: Aug 2009 Posts: 14 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 14 | My front suspension is a torsion bar with a- arms, I don't think I want to swap to a solid axle. Maybe I should research what spindle bearing an 85 chevy c30 has, then compare part numbers with mine. | | | | | Joined: Aug 2009 Posts: 14 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 14 | I wonder if I may have to take out the complete front suspension on an 79-85 c-30 and weld it in place to replace what I have now. I know thats what guys are doing on the 60's c-10's.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I think the idea was to find disc brake hubs, etc., for the front and swap them out, C-30's will probably be smaller, so, get your dimensions, then go searching. P3500's(baby school bus, etc.) came with solid and IFS front axles, so, an IFS front might be an option.
Ed
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Can you share some pictures of your spindles and or look up what king pins it uses, assuming it has king pins?
Problem with just trying to swap hubs is you still have a spindle that takes a drum brake backing plate. Advantage of swapping spindles and everything outside of them is the spindles from a disc brake truck already fit the right disc brake caliper brackets. Modifying a couple king pin bushings (if not a direct swap) is less work and a cleaner solution, possibly safer, than designing and fabricating a caliper bracket.
Ed is trying to steer you toward axle or spindle donors that also have 5/10 lug on 7.25" bolt circle, same as you already have, and these are one step up from 8 lug 1 ton stuff. I agree, for a working truck don't downgrade. The disc brakes for the 5/10 lug axles also have larger diameter rotors than the 8 lug versions, which is a good thing.
| | | | | Joined: Aug 2009 Posts: 14 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 14 | I would love to post pictures but I don't know how to do it on this forum. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I don't have any experience with them but GM did make newer disc brake coil sprung independent fronts with the 5/10 lug pattern on 7.25". Might be worth looking at one of those and your truck side by side and see if anything can be swapped from the newer one with disc. | | | | | Joined: Aug 2009 Posts: 14 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 14 | I bought a donor 1984 chevy dually truck and I'll be installing the 8 lug front suspension along with the 454 bbc and TH400 trans in my 62 chevy c40 ramp truck.
I want to run larger wheels so I guess my only option is 19.5, correct?
How would a person find 6 affordable wheels? I'm assuming that the P30 stepvan Frito lay truck wheels would work.
My truck already has a later 14 bolt rear end with 16" wheels.
