2 members (FAST55, Rusty Rod), 96 guests, and 2 robots.
Topics128,026
Posts1,055,404
Members48,422
#1226620 07/22/2017 1:09 PM
I have a 1942 Chevy truck and it needs the temperature sending unit repaired does anyone know who may repair them??? 1-262-392-2989 or [email protected]
Marv.
Ex Hall Monitor
Ex Hall Monitor
Buy a Hemming's Motor News. Lots of folks listed doing gauge repair.
Have you tested your sending unit? I see on another post that the meter is pegged after the engine overheated. Should be a way to test the unit. Maybe removing the bulb from the head and placing it in ice would be a way to try to get the needle to move. I'm sure more experienced bolters may also have some input.
Ed
Will try the ice water trick, you never know. Thanks!!!
Marv.
Ice did no work thanks anyway for the idea.
Marv.
Crusing in the Passing Lane
HRL had a comment a while back, acetone and dry ice in the bulb to keep the ether from escaping, cut and solder a new bulb on the meter.
Ed
