7 members (1955 1 Series, 3B, Jay R, Wayne67vert, Phak1, DaveV, Hush),
123
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 1,135 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,135 | Getting ready to install the painted dash and gauges. The dash screws and bolts onto the cab. The cab section has a support or cross member that runs from the A pillars on each side. In that support there are five, about 1/2" diameter holes. Two of the holes are somewhat "D" shaped. These are at the center of the support and one on each side of the windshiled crank assembly . The other three: one on each end near the "A" pillars and one about the center between the windshield crank hole and the left "A" pillar.
What is/was the purpose of these holes? I don't believe there is a missing part(s). I received this project disassembled, but the dash was apparently one of a few parts unmolested since assembly. Just want to make sure on this re-assembly so I can avoid re-working the whole dash later. I don't think they are drains, since as I learned from others recently those are in bottom corners of the windshield channel.
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Mine had the same holes. I never saw a need for them. They have no purpose that I can see. Harold
Harold Is a restoration ever finished? | | |
