Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (carbking), 141 guests, and 1 robot.
Topics128,274
Posts1,058,433
Members48,490
#1226175 07/19/2017 12:14 AM
Getting ready to install the painted dash and gauges. The dash screws and bolts onto the cab. The cab section has a support or cross member that runs from the A pillars on each side. In that support there are five, about 1/2" diameter holes. Two of the holes are somewhat "D" shaped. These are at the center of the support and one on each side of the windshiled crank assembly . The other three: one on each end near the "A" pillars and one about the center between the windshield crank hole and the left "A" pillar.
What is/was the purpose of these holes? I don't believe there is a missing part(s). I received this project disassembled, but the dash was apparently one of a few parts unmolested since assembly. Just want to make sure on this re-assembly so I can avoid re-working the whole dash later. I don't think they are drains, since as I learned from others recently those are in bottom corners of the windshield channel.
Mine had the same holes. I never saw a need for them. They have no purpose that I can see.
Harold
Harold
Moderated by  ndkid275, Phak1
