| | | Forums66 Topics128,018 Posts1,055,339 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2005 Posts: 96 | they look like steps and i have seen them before but if you look in the picture you can see they wrote "no step" inside the step. sorry i dont know where you could get them except ebay or salvage. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Lee, Try a truckstop or a large truck supplier. I've seen them there
Dan | | | | | Joined: Oct 2006 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 128 | Thanks, it looks like they're something Ford offered. There's one on E-Bay right now for $40 NOS. I'm guessing this one says "No Step" because they didn't put any kind of support behind it and you'd be supported just by the sheetmetal. They're kind of neat, but probably not all that useful unless you need to climb in the bed from the side of the truck.
Lee | | | | | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | Hey I had a 66 with the exact same things I should have kept them cause now I can't find them anywhere either.I do believe they were ment to be used as a step,but in this case the owner probably wrote this in to discourage people from climbing all over his fine machine.As far as Ican remeber they worked great with no support,but Im not sure if there was support or not.Regardless they are cool and Iwant them for my 63 napco,please let me know were or how to find these rare pieces thanks!  | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | They prolly wrote that on there so the Bondo doesn't crack  ,,Brian | | | | | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | 64 did you even look at that truck .It is by far one of the finest I have ever seen clean,straight,tight and finished.I can only hope your kidding eh! :confused: | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I put a smilie in there,,just kidding you know-but it IS on eBay & it IS resale red....& it does look like a hole in the cab corner...Brian | | | | | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | YA a drain hole I believe.They certinly aint trying to hide it.Miles ahead of half of that crap people call restored on ebay  | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Whoever took those pictures really knows how to light and photograph a vehicle. I bet it looks better in the pics than it really is.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Aug 2006 Posts: 59 Member | | Member Joined: Aug 2006 Posts: 59 | Does anyone know the "name and years " of the whells on this tk. ? Arin't they Chevy Camaro/Chevelle. I'm looking for a set for my 65 c-10 and all I see is 6 lug Thanks , George
1965 C-10 fleetside shortbed BLACK 82 c-10 longbed 6 cyl. 58 Lincoln 2-dr coupe Black w/white & blk. 59 lincoln 4-dr. parts car
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | George, they are Rally wheels, usually 68-77 or so car wheels(Camaro,Monte Carlo,Corvette), they are prolly aftermarket reproductions. Wheel Vintiques makes them I believe, Summit sells them also. Brian | | | | | Joined: Aug 2006 Posts: 59 Member | | Member Joined: Aug 2006 Posts: 59 | Brian, Thanks for the info on the wheels, now for a another question. What is the wheel bolt pattern for a front end swap that we both have both made ? I need size #'s . The reason I'm asking is that after changing to the newer front end ,the Keystones that have been on the truck for over 15 yrs. do not fit the chevy pattern. ???????? I think the hubs where nigg.... or something ! Thanks , George
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | I collect factory literature for the '64-'66 Chevy truck line. Per the booklet titiled "'64 Custom Features Accessories-For All Chevrolet Trucks", the referenced "cutout steps" are called "Pick-up Side Steps". They are described as "Permits easy access to the cargo in the front load space of the pick-up box".
They were custom feature accessories for the pick-up and panel trucks. Some of the other custom feature accessories also shown in this booklet, includes custom manual radio and antenna, seat belts, Jr. West Coast mirrors, windshield washer, power brakes, extendable rear view mirror, auxillary rear springs, front bumper guards, commercial grille guard, back-up lamps, locking gasoline cap, direction signal conversion, matched horn, hazard flasher switch, arm rest, cigarette lighter & lamp, electric clock, right hand sun visor, safety light and hand portable spot lamp.
I have found this literature and other pieces I have acquired, specifically for the '64-'66 Chevy trucks, has been very informative. It also makes it rather easy to determine what is factory/dealer accessories and what is a previous owner's bright idea. | | | | | Joined: Aug 2006 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 112 | JC whitney used to sell those
64 & 66 GMC long fleetside 4x4 Cartwright, OK
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | George F. Hood: My '65 C10 lwb fleetside "19SEXY5" has the wheels you are looking for. They are six lug Rally truck wheels with Corvette/Chevelle caps. Check it out below. \'65 Chevy C10 "19SEXY5" | | |
