0 members (), 254 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#1226042 07/18/2017 12:01 PM
Hello,
Wondering if anyone can tell me how to remove the pedal cluster, can figure out the connections to
to the brake and clutch but the main assy is where I am not sure.
Is it just that one big nut on the outside surface of the frame or is there more to it than that.
What make, year, model truck?
1954 1/2 ton PU
3B Offline
Hy posey, If you are talking about the bracket that supports the pedal shafts it is riveted to the frame on the top and bottom flanges if I remember correctly, hope that helps.
