2 members (55shaker, 1 invisible), 313 guests, and 2 robots.
Topics128,152
Posts1,057,011
Members48,460
Hi guys,
Recently and increasingly my rear wheels lock up everyone I brake resulting in a loud tyre screach even when gently braking (which is hard to do now). The rear brakes seam to be grabbing. It's very hard to brake without locking up the reads
Anyone have any ideas what it maybe ?
I have a front disc conversion. Brakes have been fine for a few years before this
The passengers side rear feels like it's locking more (brakes pull to right and tyre screach more evident on right)
Crusing in the Passing Lane
Lines clogged by swelling rubber lines, replace longs?
Ed
Check for a grease seal leak on the right rear- - - -even a little bit of oil on the brake linings will cause a brake to grab and lock up the wheel.
If you find oil on the shoes, check the diff vent. Very common for these to plug up and put pressure on the seals.
My Blog
dirt, grime and oil on the linings comes to mind first, then a faulty prop valve
Dave Chapman
The Hollister Road Company
713-937-0387
[email protected]
www.hollisterroad.com
www.thoroco.com
thanks guys for your advice. ill pull off the drums and see whats happening.
rubber hose does look quite old.
cheers
mike
New learning on the seals and grease on linings. Thanks for insight.
~ HB
1962 Chevrolet C10
1962 Suburban
Just want to thank you guys and let you know you were 100 percent spot on with your advice!
I cleaned up the oil and brakes worked again. I have a slow leak so will need to change the seal at some point
Cheers
Mike
