| | | Forums66 Topics128,035 Posts1,055,559 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | Just a curious question. On the front bed panel for a stock AD truck, do the nuts or bolt heads go on the outside of the bed? That is to say the 8 bolts that bolt the bed sides to the front panel. Obvious to me would be the bolt heads on the outside, but this area is somewhat obscured by the stake pocket and the inside of the bed is highly visible, and the outside does have the nuts from the threaded rod showing. Just curious how it was stock. TIA | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | My 59 had the nuts on the outside between the bed and cab.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Same here, on my 50 the heads are on the inside of the bed and the nuts are on the outside.
