| | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 74 'Bolter | | 'Bolter Joined: May 2005 Posts: 74 | I have a '62 with the factory grill and hood but would like to convert to a '60 grill and hood. I found a '60 donor pickup, do I need to pull anything else off the donor besides the grill and hood? | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | get the hood latch in case its different and get the headlight wiring. | | | | | Joined: May 2005 Posts: 74 'Bolter | | 'Bolter Joined: May 2005 Posts: 74 | So the grill support is the same? | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | i put a 60 grill in my 64.two top holes were the same so i bolted it in and marked the other holes to drill.i believe the 62 should be the same as the 60.the 62 grill looks like it should have been four headlights. | | | | | Joined: May 2005 Posts: 74 'Bolter | | 'Bolter Joined: May 2005 Posts: 74 | That makes it easy then.
Thanks | | |
