4 members (2-Ton, Bill Hanlon, 2 invisible),
90
Mod | | | Forums66 Topics128,142 Posts1,056,485 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2013 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 36 | 1961 Apache 10 w/235 sputtered to a stop today. Half a tank of gas and no fuel to carb. Pulled inline filter off and cranked engine. No fuel. Pulled input line from fuel pump and no fuel came out. I remember when I changed out the pump last year, fuel poured out the input line. This leads me to think I've got an obstruction somewhere. Correct thinking? If so, I plan on disconnecting the fuel line at tank and pump and see if I can get air through it. If I can what's my next step? Pull fuel tank?
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Take the fuel line off the inlet side of the pump and blow back toward the tank with your air compressor. Sounds like a blockage either in the line itself or the fitting on the tank.ðŸ›
| | | | | Joined: Mar 2010 Posts: 10,282 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,282 | Does your tank pull fuel from the top of the tank? If so, check to make sure that you have a tight connection at the fuel line at the sending unit. You may be sucking air there. There should be a sock on the end of the fuel pickup pipe inside the tank, preventing a blockage there. Carl
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Back in the day the quick fix was to blow the sock off and put a filter inline before the fuel pump. Another possibility is rusted insides to the fuel line. Took a drill motor and a piece of baling wire to the tank to pump line on a '53 one time. Cleaned it right out and never clogged again.ðŸ›
| | | | | Joined: Jun 2013 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 36 | The fuel line does enter at the top of the tank. | | | | | Joined: Jun 2013 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 36 | Disconnected fuel line at pump and top of tank and blew out with compressor. Pulled pick up tubing with float attached from tank. Blew it out with compressor also. Have everything buttoned back up now. Where do I go from here? Can fuel pumps lose their prime? How does fuel get to the fuel pump with the fuel line exiting at the top of the tank? Siphoning action? | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | I would not be uncommon for your "new" fuel pump to go bad. Parts just aren't what they use to be.ðŸ›
| | | | | Joined: Jun 2013 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 36 | Primed carb with a syringe 6 times. Fire...die...fire....die. 6th time she took off and is running great. Confused as to what caused fuel line to run dry. Truck was parked on a pretty good decline before she sputtered to a stop right after I moved her | | |
