| | | Forums66 Topics128,021 Posts1,055,351 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | My ignition switch is pretty loose. I have the rear wire connections on tight, but the 'inner body' that houses the electrical connections is not tight in the housing. If I bump the rear while opening or closing the hood vent it tends to shut off the ignition. What are the suggestions for rebuilding or having the ignition switch rebuilt? I believe the exterior "thumb switch" is specific only to the 47-48 models? Thanks Curt | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | There is a new old stock switch on Ebay right now, without the tumbler and key. The seller's name is "truckman4787". Price isn't bad, and you can swap your tumbler into the new switch assembly. Jerry
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | There are three tabs that are part of the switch case. These tabs fold over and retain the switch internals. You should be able to bend the tabs tighter while pushing down the Bakelite rear of the switch internals. If you can find the correct switch housing, the lock cylinder can be switched out. The "thumb switch" cylinder doesn't interchange with all housings. Perhaps another bolter has the correct part number for the housing you need.
Ed
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 |
GM 1116452 is the correct ignition
If you use a GM 1116464 you lose the no key feature
| | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | Thank You for all of your help Jerry, Ed & Dad50! I am going to remove it and see if I can't re bend the tabs enough to secure it.
| | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | I recently tightened up my loose switch by securing the switch in a vice and used a small diameter punch and hammer to mash it a little tighter. You can see where they were dented in originally (probably with a press) in 3 places.
| | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | | | |
